NEED YOUR HELP!! Red wire, Yellow wire, & Black wire
Ok guys I need your help. I am installing a new electronic device(heads-up display) on my friends car and want to verify the wiring. It purchased open box, did not come with install directions nor wiring info. which wire is which?
- Red wire <-- ?
- Yellow wire <-- Power?
- Black wire <-- Ground?
Helpppppp
- Red wire <-- ?
Helpppppp
Re: NEED YOUR HELP!! Red wire, Yellow wire, & Black wire (red1997civic)
yellow usually is constant wire. depending on what it is you are puttin in.
red is 12v switched
black ground
red is 12v switched
black ground
my guess would be-
red switched power
black ground
yellow constant power (memory)
similiar to the wiring with all stereo's... just try one way and if it doesnt work right then switch them up...
red switched power
black ground
Re: (dunkd)
if its the same wiring as a radio then
red = switched ignition 12volts
yellow = constant 12volts
black = ground
if its wiring like an alarm system then
red = constant 12volts
yellow = switched igniton 12volts
black = ground
you cant really **** nohtin up by switchin the 2 but it may not keep memory the correct way if its wrong..
black = ground
black = ground
raidacaipo
05-12-2008 08:07 PM
