coilovers? shocks? both?
i have a 94 si hatch and i am about to lower it, i want it to be adjustable, but i dont know whats best, i was thinking about a package of skunk2 adj coilovers and tokico blues adj shocks then skunk2 tower bars, antiswaybars, camber correction, tie rods. but shoudl i just get a full coilover kit like the tein SS, it will be about the same *** the stuff i said, price wise, but i wont get the swaybars tower bars camber or ties......what do you guys think....also, did i leave anything out on what i need?
Re: coilovers? shocks? both? (N21)
Depends on what you'll be using the car for. If you're going to be on the track often get the Tiens, otherwise save your money.
i would only get the tein ss if you are going to see track time, otherwise the skunk2/tokico illuminas(the blues aren't adjustable and rides rough)would work for street/strip(my setup). get the camber kits to prevent uneven tire wear. if you want an even smoother ride for the streets, go with off-the-shelf ground control because they have softer spring rates, or you could just get the tein basic damper kit(no adjustability of the damper forces). hth.
jus f0 dekarayshunZ
Re: coilovers? shocks? both? (cycocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycocivic »</TD></TR><TR><TD CLASS="quote">i would only get the tein ss if you are going to see track time, otherwise the skunk2/tokico illuminas(the blues aren't adjustable and rides rough)would work for street/strip(my setup). get the camber kits to prevent uneven tire wear. if you want an even smoother ride for the streets, go with off-the-shelf ground control because they have softer spring rates, or you could just get the tein basic damper kit(no adjustability of the damper forces). hth.</TD></TR></TABLE>perfect...some people do too much with there suspension when they dont need to ...if your gonna see a track you want some stiffness...but if not...gc's should be fine
Skunk2 coilovers on tokico shocks. DO I NEED CAMBERS WITH 2inch drop??suspension installation. urgen
Ratchback
10-05-2004 10:19 PM
