how do you clean the air blower?
i found the thread on here but it doesnt show you how to. i dont know where to start or where its located. but im jus thinkin under the passenger side dash? help me on this.
Re: how do you clean the air blower? (wizzards581)
If your talking about the AC fan...it should be under your dash in the glove compartment area. There should be 3-4 bolts holding the fan motor in. The fan and motor will drop down as a single unit. Then you can hose it off or whatever...
Re: how do you clean the air blower? (axhandler)
I would assume he's talking aobut the blower motor. If you have A/C (at least in an EK) you have to take out your A/C condenser and it's in above that.
Re: how do you clean the air blower? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I would assume he's talking aobut the blower motor. If you have A/C (at least in an EK) you have to take out your A/C condenser and it's in above that. </TD></TR></TABLE>
lol the condenser is the one at the front of the car that sits beside the radiator. Maybe you are talking about the evaporator.
Re: how do you clean the air blower? (Emong3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emong3 »</TD></TR><TR><TD CLASS="quote">
lol the condenser is the one at the front of the car that sits beside the radiator. Maybe you are talking about the evaporator. </TD></TR></TABLE>
That's the one. Long day.
well like this thread... and pics in there
https://honda-tech.com/zerothread?id=457308
how do you get access to that.. theres no write up..
so thats why i dont know where to start.
It's just like I said man. The fan motor is underneath your dash on the passenger side. It has 3 or 4 bolts holding it in. If you go look it will be pretty obvious. If you still cant find it I'll take a picture for you...
You dont need to remove anything but the three bolts on the bottom of the blower motor.
Re: how do you clean the air blower? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
You dont need to remove anything but the three bolts on the bottom of the blower motor.</TD></TR></TABLE>
How sure are you about that?
I tried to get to just the blower motor and it was a big no-go. Even the Helms said I had to take out the evaporator.
I tried to get to just the blower motor and it was a big no-go. Even the Helms said I had to take out the evaporator. </TD></TR></TABLE>
What year and model?
What year and model?</TD></TR></TABLE>
97 DX hatch.
97 DX hatch.
97 DX hatch. </TD></TR></TABLE>
As sure as I can be. I've cleaned out and/or replaced dozens of them. There are three bolts holding the blower motor in from the bottom. If you want to take the whole blower box out you may need to remove the evaporator, but not for just a motor.
As sure as I can be. I've cleaned out and/or replaced dozens of them. There are three bolts holding the blower motor in from the bottom. If you want to take the whole blower box out you may need to remove the evaporator, but not for just a motor. </TD></TR></TABLE>
Well damn. The motor has the part that you actually need to clean correct?
Well damn. The motor has the part that you actually need to clean correct?</TD></TR></TABLE>
Yea, the squirell cage comes out with it. They tend to collect leaves and rats nests.
Yea, the squirell cage comes out with it. They tend to collect leaves and rats nests. </TD></TR></TABLE>
x1000 man. Can you direct me to these 3 bolts?
x1000 man. Can you direct me to these 3 bolts?</TD></TR></TABLE>
On the bottom going straight up. They have 8mm heads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">what about EG??</TD></TR></TABLE>
They're the same.
They're the same.
hans stoner
07-24-2006 03:11 AM
pezzy
08-20-2004 03:29 PM
