How do I wire a b16a into my 98 civic ex?
98 jdm b16a sir II swap using a 98 ex harness and a 99-00 si ecu
Do I need to extend the 2nd o2 from the ex harness? Where is it located? Ty newbie here.
Technical Hero
Re: Need directions on how to wire in a b16a in a 98 civic ex
The secondary 02 is in the cabin harness that runs to the catalytic location under the car. However if he was using an OBD1 ECU it won't look for one and generally you can leave it in the same place as long as the header lines up to the stock exhaust.
Cool Cool Island Breezes. BOY-EE
OP....take it to a shop if you're uncomfortable with wiring.
For it to run, you'll need to rewire the distributor or get a distributor jumper. You'll also need to lengthen the primary O2 wires. The rest plugs in. You don't re-pin sandwich harnesses. The whole point of them is to be plug and play. But.....they're very fragile. So don't yank on the wires.
Ty guys lets give u my set up run down I have a 98 dx hatch with no 2nd o2 in the cabin correct?
I Doing a 98 jdm b16a sir II Swap Useing the 98ex harness Running that harness to a 99-00 si ecu
So far everything was plug n play now I have 3 plugs left over n don't kno where they go lol
?questions r is this plug for the crank sensor?
Plug next to injectors
Srry for the ugly pic I'm total newbie. Can't even navigate the site. Anyways
Here's the 2plug under the manifold
Is that's 2nd o2. Tat goes to the catalytic converter that I extend ???
Or. Do I do that or pin that out on da p2t si ecu
With all that said do I still need a jumper from odb2a harness to a odb2b ecu Lil lost
And yes I am trying to get it bard n legit for my dd Any guidance is much luv n appreciate. Ty guys
Technical Hero
Correct both are in front on the exhaust manifold
Youll need an OBD2A to OBD2B ECU adapter
So far everything was plug n play now I have 3 plugs left over n don't kno where they go lol ��
?questions r is this plug for the crank sensor? Looks like either evaporated purge or IAT. What color are the wires
Ty hero. Yep I think ur right the first 1 goes to purge nxt to injectors on the fuel rails I was missing that.
Second plugs has to b crank sensor Yep have to do by pass
Third plug. Is I still don't kno lol. I bout si harness to help me out n that don't have it either
Hmmm Don't think it's fan. Will double check on that tho. Will post colors ASAP on that. Srry been Mia Holliday run arounds.
Again Ty guys Ty hero ur my hero.
Fish Twig
If you can get the color code of those wires from each plug, but the 3 pin wire near the alternator could be the crank sensor plug, the 2 pin looks like the oil pressure sensor plug for the vtec solenoid, but since jdm motors don't have that and only have the vtec solenoid you might need to ground it.
Re: How do I wire a b16a into my 98 civic ex?
Ok had the plug next to the cap is. Colored black / blue with black ?
N yes the plug under the manifold is for the crank sensor. So do I just clip it off and hide it.
Also do I do the ckf bypass on my ex harness?
I'm ordering a jumper on Monday hope there's a sale lol
Or do I do it on the jumper cuz I am running it into a 99-00 si ecu.
I kno I still need to tap splice my wires to make my o2 that goes to the catalytic converter.
I my question is I'm doing all this tapping n splicing on my ex harness correct???
N just plug that into the jumper. Then to the ecu ???
Thanks guys.
Thanks guys.
Tony u may right. U just reviewed the page that u had provided (hero) black/blue-black is oil pressure So just ground the black. N leave the blue-black clipped n tuck. U say tony?
Technical Hero
Yes bypass the CKF
.:FFS TechNet : CKF Bypass Trick :.
Pressure switch bypass, tap b12 with c10 On your jumper side harness
Wire up secondary 02
.:FFS TechNet:. » ECU & WIRING » OBD2 2nd 02 Sensor Wiring
Then use your ECU jumper
Ty hero. So. All of my tap n splice are all done on the jumper correct!? And not my ex harness. N follow the ecu guide for obd2b correct?
Here's is a pic of my ex harness running into the 99-00si ecu. The jumper will let me have all 3 plugs plug in then do my tap n splice right????
Fish Twig
For any b-series the primary sits behind the engine, for the D-series the primary sits in front of the engine.
Hmmm 98civic dx hatchback is my model
I am using a ex engine bay harness
So for the confusion. Tony. Thought I have gave u guys that info. Already on my run down set up.
98civic dx hatchback. Swapping a 96-98 sir 2 jdm b16a /obd2
Using a 96-98 civic ex engine harness.
Running into pt2 99-00 si ecu.
Tat is my set up. Tony
Technical Hero
Here's is a pic of my ex harness running into the 99-00si ecu. The jumper will let me have all 3 plugs plug in then do my tap n splice right???? ��
sorry I just looked it up and tagged on to it. Sorry for the confusion guys I'm still noobie trying to navigate around n use the site. My apology tony. Again sorry
And thanks for all of the luv guys
roro1
09-27-2013 10:44 PM
HondaTom87
13
03-17-2013 02:43 PM
Lissav
02-06-2008 12:48 PM
B96v6
12-16-2005 06:34 AM
