How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP!
Old 09-14-2004, 08:54 PM
vtec25's Avatar
Default How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP!
ok so i got a code 5 MAP - manifold absolute pressure sensor so i go check my engine bay and i have a map on the top of the throttle body and one on the firewall. the one on the firewall has the hoses cut and are plugged up with screws. thats not right. right?? where do those go to?? and what should i do??? please help my car feels real sluggish and backfires real bad and i dont know what to do. i have a 92 civic dx with a d16z6 swapped in(previous owners did it).
Old 09-14-2004, 10:06 PM
vtec25's Avatar
Default Re: How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP! (vtec25)
bump
Old 09-14-2004, 10:22 PM
Luserkid's Avatar
My MAP thats on the firewall is closed up like that, but also its not wired up either. Yours might still be wired up so its throwing that code.
If you could get a picture i could tell you were each one does. I just tried typing it up but it makes no ******* sense without a picture sorry
Old 09-16-2004, 02:34 PM
vtec25's Avatar
Default Re: How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP! (Luserkid)
Old 09-16-2004, 04:07 PM
Luserkid's Avatar
Thats really messy first thing i would do is clean it off. Then this is how my map sensor goes. Its just hosed to itself and then one open and its good to go. Heres 2 pictures.
Try this and see if that works, yours is to messy to see what goes to what. Also look around the manifold and see if you see any vaccum leaks or any spots that are without a hose.
HTH
Old 09-23-2004, 02:20 PM
vtec25's Avatar
ok i got mine to look exactly like that but still have cel. do i have to replace it??
Old 09-29-2004, 10:35 PM
vtec25's Avatar
BUMP
still got the cel and i'm backfiring like a itch. How can i check if it needs replacment???
Old 09-29-2004, 10:58 PM
Luserkid's Avatar
did you reset the computer?
Old 09-30-2004, 03:24 AM
pnltnc's Avatar
I had the same problem with my gsr swap...What i did was disconnect from the firewall map sensor and connect to the throttle body, then reset the computer.
Old 10-06-2004, 08:26 PM
vtec25's Avatar
Default Re: How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP! (pnltnc)
THANK YOU pnltnc
i did that and poof no more cel or backfiring and my idle is normal now.
FSS13foxtrot
01-20-2008 06:23 AM
92ehatch
16
02-19-2007 11:41 PM
JasonST
04-26-2006 07:36 AM
slowazzhatch
06-01-2003 07:42 PM
Quick Reply: How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP!
