how do I empty my prestone?
Old 05-23-2005, 05:28 AM
TealCivic93's Avatar
Default how do I empty my prestone?
search = found nothing.
Old 05-23-2005, 05:44 AM
AutoXer's Avatar
Default Re: how do I empty my prestone? (TealCivic93)
You mean drain the radiator?
There is a plastic plug at the bottom of the radiator, there will be a gap in the plastic splash guard under the car which will help you find it.
That will drain the radiator. To drain the coolant from the block, there is a big drain bolt (I seem to remember 19mm?) up and to the left of the oil filter.
Old 05-23-2005, 05:56 AM
Default Re: how do I empty my prestone? (AutoXer)
ok thanks. Yes it was to drain the radiator. What are the consequences of running water in the radiator?
JF
Old 05-23-2005, 06:02 AM
Toxidomask's Avatar
consequences?? what do you mean? like flushing it? it wont hurt. but in refilling it, you still need to use a 50/50 of coolant/water.
Old 05-23-2005, 06:05 AM
why 50/50? i can't put 100% radiator fluid? what if I have been running water for a month now?
Old 05-23-2005, 06:44 AM
AutoXer's Avatar
Default Re: (TealCivic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TealCivic93 &raquo;</TD></TR><TR><TD CLASS="quote">why 50/50? i can't put 100% radiator fluid? what if I have been running water for a month now?</TD></TR></TABLE>
You can just run water, if there is no chance of freezing; but it must be distilled water, or it can have a reaction with the metal inside the radiator.
If you run 100% coolant, you're wasting money and it may not be good for the metals in your motor and radiator. It's meant to keep the water from freezing in the winter, and actually doesn't cool as well as water.
I use the prestone pre-mix, because you only need 2 bottles to do a complete flush and fill; so I don't mind paying extra for it.
Old 05-23-2005, 08:20 AM
ok thanks for the info. So first thing first I flush the water out, then I put in the 50/50 mixture? or is there other steps in between?
thx
Old 05-23-2005, 08:25 AM
Electrician
Deemeetree's Avatar
I usually drain the coolant. Stick a water hose in there with the valve open and let it completely flush out until you see pure water coming out. Then, fill up with Prestone 50/50.
justinwebb
23
05-06-2009 08:24 PM
batac_boy
Honda Civic (2001 - 2005)
03-23-2008 05:59 AM
MYKJDM
06-02-2007 06:09 AM
jdmspoonitr
04-14-2005 09:58 PM
FD3S
04-20-2003 04:22 PM
Quick Reply: how do I empty my prestone?
