How to check and add tranny fluid to a D16?
Old 06-05-2005, 03:42 PM
DBLAZE's Avatar
Default How to check and add tranny fluid to a D16?
Just as the title states...How can I check the fluid on my D16???
Old 06-05-2005, 03:46 PM
97civicdx's Avatar
Default Re: How to check and add tranny fluid to a D16? (DBLAZE)
There is a bolt just above the tranny drain bolt. take it out and fill new fluid until is comes out. I used the VSS sensor on top to refill.
Good Luck.
Old 06-05-2005, 03:47 PM
DBLAZE's Avatar
Default Re: How to check and add tranny fluid to a D16? (97civicdx)
good info, but does anyone have a good pic they can show me???
Old 06-05-2005, 03:50 PM
Luserkid's Avatar
https://honda-tech.com/zerothread?id=382416
Same way for all Honda Tranny's
Old 06-06-2005, 04:37 PM
hybridmyk's Avatar
Just go underneath ur car. There is a plug on the tranny that you can stick a 1inch socket wrench into.(u kno, the square thing at the end of the socket wrench where the socket fits on to) This fits right in there. this is where u drain and fill ur tranny fluid. it'll need 2 quarts of 10w30 or i prefer honda manual tranny fluid. Only like $3-4 bottle. You need a funnel with a hose to fill it back up. get that at walmart or something. just fill back up to the drain point. when it starts leaking out, it's full. Then just plug it back up n ur good to go. Gud luk.
ef dino
12-04-2006 09:29 AM
Adrian G. Aka JDMonkey
10-18-2006 04:17 PM
H22A4Me
01-27-2006 07:55 PM
pelotudo
07-21-2002 02:33 AM
Quick Reply: How to check and add tranny fluid to a D16?
