how to camber rear!!!!! help
i need help on how to fix camber in teh rear wheels i heard you can use washers??? how many washers and what size?? if anyone got a diy it would really help i got a 98 civic ex with neuspeed springs on stock shocks thanks
Re: how to camber rear!!!!! help (pdiggitydogg)
thats helpful thanks, would i need a thicker washer since my springs are 2.0 in the back?
Re: how to camber rear!!!!! help (FifthGearOnline)
haha best way to work on ur car....calm and relaxed least amount of brain cells at work
Re: how to camber rear!!!!! help (dash0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash0n »</TD></TR><TR><TD CLASS="quote">haha best way to work on ur car....calm and relaxed least amount of brain cells at work </TD></TR></TABLE> Unless your still using the spring compressor... + dangerous tools = = but at least you wouldn't feel it.
Re: how to camber rear!!!!! help (98Hatch00)
wat if i didnt use the 45mm bolt but instead i just use the stock bolt with two washers, it still bolt on tight and enough thread to make it tight.
Re: how to camber rear!!!!! help (Ignitecivic)
id take a guess and say it would be safer just to get another bolt, only cost you a buck or two instead of having ur sh*t fall off while ur driving
hahah i know damn i already did it cuz home depot ran out of the m10x 1.25 45 mm. i got the 50 and its too damn long. thanks for the tip man. i guess imma put it back then do it later when i get the bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">wat if i didnt use the 45mm bolt but instead i just use the stock bolt with two washers, it still bolt on tight and enough thread to make it tight.</TD></TR></TABLE>
Some people still use their factory bolts - up to 2 washers and thread locking compound...
Re: how to camber rear!!!!! help (all stock)
crap....jdmfan.com seems to be down for me anyone got the specs on what type of bolts and washers to use btw how many should i use for my rear 2" drop??? thanks....another diy page would be nice...
Re: how to camber rear!!!!! help (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">What grade bolt ?????</TD></TR></TABLE>
I believe it's 8.8 or better
jtoribio312
Suspension & Brakes
01-26-2008 12:04 PM
tshuajzoo559
03-12-2007 03:03 PM
