Rear Camber trick??..using Washers??
Need help...has anyone ever done this before or even heard of it?...People that done it says its the cheap way of doing the rear camber using some kind of washer...and it works like the aftermarket..Please help me out..
Need to know..
-what size washer?
-how long will it last?
-does it really work?
Need to know..
-what size washer?
Darth ModerVader
Re: Rear Camber trick??..using Washers?? (tshuajzoo559)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 »</TD></TR><TR><TD CLASS="quote">-what size washer?</TD></TR></TABLE>
Whatever size will fit on the bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 »</TD></TR><TR><TD CLASS="quote">-how long will it last?</TD></TR></TABLE>
Assuming you use washers that don't completely rust and disintegrate, it will "last" indefinitely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 »</TD></TR><TR><TD CLASS="quote">-does it really work?</TD></TR></TABLE>
Yes, it does, as long as you aren't trying to correct ridiculously negative camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 »</TD></TR><TR><TD CLASS="quote">thanks...bump for more info</TD></TR></TABLE>
that link is all you need to know.
B HATCH
132
07-23-2005 03:16 PM
xXx Justin xXx
26
10-22-2004 03:41 PM
