Hot ass air in EK.
Hot *** air in EK.
I have this EK, and my climate control slider is broke, and stuck in the hot/red position if that matters.
Normally I don't have any air coming out, but yesterday one of the vent buttons was pushed on accident, and I pressed it, and another one simultaneously, so none would be lit up. So, it should be off, but I have this hot *** air in the goddamned car. It's already 90 degrees! I don't need hot *** air!
Re: Hot *** air in EK. (ThatEKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aak »</TD></TR><TR><TD CLASS="quote">is the recirculation button lit? if not, that will keep anything from coming out of the vents. sorry for your situation </TD></TR></TABLE>
WTF??
go under the hood and close the little door in the heater hose leading to the heater core, its a little black thing with a lever and a wire attached to it
WTF??
Re: Hot *** air in EK. (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">
WTF??
go under the hood and close the little door in the heater hose leading to the heater core, its a little black thing with a lever and a wire attached to it</TD></TR></TABLE>
i dont know about you guys , but my ek is always blowing air thru the vents just slightly-- if its in the hot position it lets out hot air cold cold air ...
WTF??
On my 93 LX, and I would assume the air system is similar on this car, on the passenger side, look down underneath, kind of in behind the ash-tray console area, there's some cables and so on for the air system there. It's hard to describe where the cable goes for the hot/cold setting, but it goes to a rod there and you can change the setting by moving this rod. It's easier than it sounds, just look around there and you should be able to find it.
chek
01-01-2010 06:24 AM
Chris y0!
05-20-2003 04:01 PM
