Honda recommends 5w-30 oil... are there any exceptions?
Old 03-04-2007, 02:55 PM
allricedout's Avatar
Default Honda recommends 5w-30 oil... are there any exceptions?
i accidently bought some 10w-30 M1 syn. and AFAIK the 10w (is the weight when oil is cold) and the -30 is the weight under normal operating temps or something similar.
can someone please clear this up....
Old 03-04-2007, 03:06 PM
Chim Chim's Avatar
Default Re: Honda recommends 5w-30 oil... are there any exceptions? (allricedout)
Yeah, there was a couple TSBs put out a while back... They recommend 5w-20 on 1996 and newer civics... So it's really up to you. I don't think 10w-30 will hurt unless you're doing cold starts in near freezing temps....
Old 03-04-2007, 03:10 PM
cute little bastard
SkoundrelUSA's Avatar
10w-30 is fine. I used to use that until one night I left my car out and it was like 20 degrees C outside and couldn't get my car to idle on its own.
Old 03-04-2007, 03:21 PM
forcefedferio's Avatar
you will be fine with 10w-30...and yes there is exceptions i.e. ACL calls for 20W-50 with their rod bearings
Old 03-04-2007, 05:20 PM
yeah, i figured the heavier initial weight wouldnt hurt the internals.
however, if honda reccommended 20w and i put some 5W in there might be a problem.....
unless i had ACL rod bearings, which i dont. unless? no
Old 03-04-2007, 05:33 PM
cute little bastard
Default Re: (allricedout)
dude you have a CX. Its not gonna care lol
Old 03-05-2007, 06:39 PM
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">dude you have a CX. Its not gonna care lol</TD></TR></TABLE>
i only get 29.9 mpg, do you think using 5w-30 will increase mileage? neone
Old 03-05-2007, 08:00 PM
Dilly's Avatar
i use 10w-30 in the summer and 5w-30 in the winter...
Layziejoe775's Avatar
i think so...i use 5w-30...ever since...i have about 93xxx..and it's working fine...however i have to pour oil time to time....oinly becuz i have a small leak on the oil pan threads.
Old 03-05-2007, 08:34 PM
TittyBoy's Avatar
hell yeah to 20w50
Old 03-06-2007, 10:10 AM
so will using a heavier weight oil decrease gas mileage efficency?
Old 03-06-2007, 10:14 AM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">so will using a heavier weight oil decrease gas mileage efficency?</TD></TR></TABLE>
Yes, but since 5W-30 and 10W-30 both perform like a 30 weight at operating temperature, there will be no real difference between the two. The main issue is with cold-start lubrication.
Old 03-06-2007, 10:17 AM
Jakester9500's Avatar
if you live somewhere that is generally a lot colder than most places in the winter, than i would say not to do something heavier. otherwise, it's all good. i just put some 10w-30 in mine, works just fine.
Old 03-06-2007, 10:22 AM
liquid:cooled's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but since 5W-30 and 10W-30 both perform like a 30 weight at operating temperature, there will be no real difference between the two. The main issue is with cold-start lubrication. </TD></TR></TABLE>
that is a good point... no difference really, only at initial startup.
Old 03-06-2007, 11:14 AM
ek4h's Avatar
Default Re: (mello)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mello &raquo;</TD></TR><TR><TD CLASS="quote">
that is a good point... no difference really, only at initial startup.</TD></TR></TABLE>
x2
Old 03-06-2007, 11:17 AM
YoungKadafi's Avatar
yea doesnt the 96 d16y8 require 5w20?
Old 03-06-2007, 11:24 AM
Syndacate's Avatar
Default Re: Honda recommends 5w-30 oil... are there any exceptions? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">10w-30 is fine. I used to use that until one night I left my car out and it was like 20 degrees C outside and couldn't get my car to idle on its own.</TD></TR></TABLE>
10w-30 is fine.
****, 15w-50 is fine if you let it warm up long enough.
My dad ran 15w50 YEAR ROUND in his Mercedes 300E. Then when I took it from him after I sold him my Jetta I kept using 15w50 year round. Damn car last 365,000 miles and it still was running fine, I SOLD IT for a few thou after my friend blew the tranny.
In terms of stock cars the variety of oil weighs can range.
I would normally run 5w-30 but I'm running 10w-30 b/c there was nothing else in the shop when I did my oil change
Suppose it really doesn't matter, just g2 make sure it's warmed up b4 blasting off.
Old 03-06-2007, 03:03 PM
Chim Chim's Avatar
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">yea doesnt the 96 d16y8 require 5w20?</TD></TR></TABLE>
No... Honda put out a TSB last year or so recommending using 5w-20 in "all" civics 1996 and newer... In the manual, it states, if 5w-20 is not available, 5w-30 is an acceptable substitute... So it's really up to you what you want to use...
Old 03-06-2007, 03:05 PM
Syndacate's Avatar
Default Re: (Chim Chim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">
No... Honda put out a TSB last year or so recommending using 5w-20 in "all" civics 1996 and newer... In the manual, it states, if 5w-20 is not available, 5w-30 is an acceptable substitute... So it's really up to you what you want to use...</TD></TR></TABLE>
I rather use 5w30 than 5w20. Better in the heat, equal in the cold.
Old 03-06-2007, 04:24 PM
im gonna take it back and get some 5w-30
Old 03-06-2007, 04:35 PM
knockout's Avatar
5w-30 for areas with temperatures averaging below 50 degrees.
10w-30 for areas with temperatures averaging above 50 degrees.
Honda recommends using 5w-30 all year round for fuel economy, but says 10w-30 is acceptable if your areas temperature never goes below 20 degrees.
It all depends on your area. I use 10w-30 year round personally because I live in southern california, so it never really goes below 40 in the winter and averages 70-90 tops in the summer.
Old 03-06-2007, 08:22 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Just use the factory 5W-30. Yes it will affect gas mileage positively. Why would you use anything else on a (im assuming) internally stock D16Y7/D15B (depening on which CX you own)??
Vague
27
08-22-2015 03:59 PM
b20beast83
08-07-2009 09:01 AM
boostedeghatch
04-25-2005 08:03 PM
X2BOARD
10-07-2004 12:55 PM
Reelizmpro
08-31-2004 05:28 PM
Quick Reply: Honda recommends 5w-30 oil... are there any exceptions?
