Manual Transmission Oil Weight?
Sup Honda fam I have a 97 Civic DX Non LS Trans and I can't seem to find a straight answer about which weight of oil I should use for my tranny, right now I'm using Conventional 5W20 not sure if this is to thin or not but I wanted to get a little more insight from you guys what do you all think?
Re: Manual Transmission Oil Weight?
Before honda had MTF they use to specify 10w30 iirc, otherwise use honda MTF, its about $8 a quart at the dealer by me
old spec MTF was about equivalent in viscosity to 10w30 engine oil. in transmission oil numbers 10w30 is most similar to 75w90. see below.
new spec is more like the 5w20 you're using now. I've yet to see regular, off-the-shelf, non-track spec transmission oil that thin. go with the MTF from Honda. you can find deals ordering it online as some dealers tend to over charge for it.
I never narc'd on nobody!
Honda Fluids - Bernardi Parts
My go-to guys for OEM fluids, lubes, sealants, and all those other fun chemicals. Except HondaLok. I get that for free from the local dealership every time I get something.
Cool Cool Island Breezes. BOY-EE
Found cases of 12 Honda MTF quarts for $88 shipped on eBay. Or on Amazon, they vary from $8-$9ish including shipping. You need 3 quarts (~2.3 qts) . Problem with Bernardi is the shipping rates. If you have a large order, you can absorb the shipping. But for small stuff, its a bit pricey....especially for fluids since they upcharge the shipping on that.
M1 is like $7-8 per quart. Honda MTF is $8-9 per quart at a local dealer. Not much difference in cost. Dealers always have it in stock. So as long as you have a local dealer, the availability is the same for either as well.
I'm sure you're fine with 10W30 and you may not ever see an actual problem. MTF does offer advantages, though.
Torco MTF is another good one. Amazon has them for $10/qt. It improved the shifting feel on my S2000 and made the trans a bit quieter. It also doesn't get that notchy shift feel after 2-3 track days like the Honda MTF. Although, Honda MTF still has better cold weather shift feel. Since this car sees almost no cold weather use...Its not really a factor.
I use Honda MTF in my TSX daily driver at about a 35-40k mile interval. Shifts like silk even in the crazy silly Chicago winter.
I'm not Rick!
aquafina doesnt show around here much anymore, but he is a tranny guru. he knows the size of teeth to the types of metal used to the capatability of other parts to make a hybrid trans etc. he coudl give a good answer
Torco MTF is usually his recommendation over Honda MTF.
I was just going to say this. Everytime I've seen him (@Aquafina) recommend fluid for our manual trannies it's always Torco MTF over all else or Torco RTF if you are abusing and can spend the extra.
And if I recall, he also said conventional 10w30 over the latest version of Honda MTF but I might be remembering incorrectly there. I do know he said avoid synthetic 10w30 like the plague.
toe may toe - toe mah toe
poe tay toe - poe tah toe
Or are you upset that there are those who think other fluids are better than your holy grail Honda MTF?
Nope. If you check my build thread, you'll actually see that I'm using Torco MTF for a stock, basic, normal DD, Honda MTF all the way. It's affordable, and it's reliable. For aggressive driving, Torco MTF, easy. For track/real performance use, Torco RTF. For the average user, though, there's no reason to waste the money on Torco when Honda MTF does the job just fine.
Makes perfect sense.
PHANTOM MENACE
I was actually wondering about my memory as well, I read through this thread a few weeks ago and was surprised at how many people were saying to use Honda MTF when in my head I was thinking that for older transmissions (specifically before Honda changed the MTF formula) it was recommended to use regular 10W-30 motor oil.
