What Weight Oil for Build Motor
What weight oil should i use in my Srp/ Eagle Built B16a motor?
Acl Rod and Main bearings.
.0015 clearance.
I was thinking castrol 10w30
.0015 clearance.
Re: What Weight Oil for Build Motor
You can probably use 10w30, since it's not very loose. A thicker oil doesn't equate to a tougher oil. The reason is the viscosity gives you less flow overall, less efficiency. It will also sap a sliver of power. On my loose D16 (on the edge at .0018) I use conventional 10w40 for a little more oil pressure, but only when it's very hot. I still get >30mpg, so don't worry about the negatives much.
cwf1988
11-02-2006 11:17 AM
