Help, what do i do about this sensor, see pics ------>
both pics are about a sonsor located behind the intake manifolds. the first pic is of the a d16 i took out my 95 civic. the second is from the b16 im putting in(sorry i couldnt get the same angles). notice that the top pic has a black sensor with a hose plugged in to the manifold. the bottom pic doesnt have it nor a place to bolt the sensor down. i was planning on using the one from the d16 and bolt it else where on the b16's manifold. but my main concern is where am i gonna hook up that hose to? i was thinking of using a tee from another hose. but im not even too sure what this sensor is since i dont have my helms with me so if u guys can help me out on this i would really appreciate it
-originally i posted this on the HYBRID forum, but i need some feedback. tia
Re: Help, what do i do about this sensor, see pics ------> (sirminder)
i actually drilled a hole in my type r manifold for the hose,then used a piece of metal vaccum line and put a little silicone around it,no problems here.there was alittle spot on the type r manifold right where the hole was suppose to be,looked stock when i was done with it,look on your b16 manifold around the bottom of the backside and see if there is a small flat spot.
Looks to be the map sensor on the 95 mani, can you take some more pics of it....
If it is your map sens. and your new motor does not have one jsut unbolt it and hook it to the firewall and run a vacum line.
Jesse
Jesse
Re: Help, what do i do about this sensor, see pics ------> (monsta)
NOT even close,its the evap purge solenoid,it circulates vaccum through the charcoal canister for fuel vapor.
[Modified by civictypenos, 3:41 PM 6/10/2002]
Re: Help, what do i do about this sensor, see pics ------> (civictypenos)
i teed a line off of the FPR to the evap. i didn't have anywhere to mount my evap though its just hanging.
If you are running a jdm ecu, then foget 'bout it. You wont need that sensor. But that is your evap purge control solenoid, as stated above.
i'm wondering the about the same question. so what should i do with that Purge sensor? just leave it hanging there or what???
Re: Help, what do i do about this sensor, see pics ------> (Jackson)
im running the jdm b16 on a chipped p28. so would a tee work fine?
Shawn
Hondatypr636
08-22-2011 11:19 AM
sirminder
06-09-2002 11:39 PM
