Help, throwing a code
Old Apr 21, 2005 | 06:58 AM
KrazyMC's Avatar
Default Help, throwing a code
wandering wat is code 21,22,and 41. I believe 41 is primary o2 sensor. i dont know the others. help plzz
Old Apr 21, 2005 | 07:07 AM
IHateJDM's Avatar
Default Re: Help, throwing a code (KrazyMC)
vtec solenoid, vtec oil pressure switch, and o2 heater circuit (o2 sensor is code 1). What engine/ecu and year?
Old Apr 21, 2005 | 07:14 AM
KrazyMC's Avatar
b16 sir2 /ecu p30 / civic hatch eg
Old Apr 21, 2005 | 07:21 AM
Jmunk's Avatar
Sounds like the VTEC solenoid isn't wired up, same with the pressure switch.
Old Apr 21, 2005 | 07:25 AM
IHateJDM's Avatar
I'm guessing vtec is not wired correctly. You may have your solenoid and pressure switch backwards (i did it too the first time). The solenoid is the one wire plug (A4), pressure switch has a hot (D6), and ground (A26). O2 heater (A6) should be orange/white. Those pinouts may not be 100% right, that's how most all obd1 is wired, and a lot of obd2 shares the same pinouts for these. Someone please correct me if I'm wrong there. You may also be able to ground the pressure switch to the head. Some ecu's look for it, some don't and i'm not sure on the p30.
bluecivic11
Sep 3, 2007 06:28 PM
lshatch92
Mar 27, 2006 10:04 AM
tinkerbell
Jan 1, 2005 08:00 PM
mannysir
Apr 20, 2002 02:19 PM
