code 41 what is it
Old Apr 20, 2002 | 01:38 PM
mannysir's Avatar
Default code 41 what is it
on a civic si obd2 what is the code 41 and also 22 and what sould i do about them .
Old Apr 20, 2002 | 02:10 PM
inspyral's Avatar
Default Re: code 41 what is it (mannysir)
22 - VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
* not a valid code if car does not have a VTEC engine
41 - Primary Oxygen Sensor - Heater
circuit malfunction
Try cleaning out your VTEC solenoid with some clean for the 22, and make sure the wiring is good.
For the 41, either your O2 is fouled out, or the heater circuit wiring is bad.
Those would be my guesses.
Old Apr 20, 2002 | 02:16 PM
simike's Avatar
Code 41: (Detection item) Primary heated O2 sensor heater, (Probable cause), Open or short in primary O2 sensor heater ciruit.
Code 22: (Detection item) VTEC system malfunction, (Probable cause), Short or open in VTEC circuit, bad VTEC solenoid valve, bad VTEC pressure switch.
For code 41 i would make sure there is no damage to the O2 sensor or wires and make sure it's not missing. For code 22 i would check the wiring on your VTEC controller if you have one and check your oil. VTEC runs off oil pressure and if it is low it may cause problems. Thats all i could guess. Good luck
Old Apr 20, 2002 | 02:17 PM
simike's Avatar
Default Re: code 41 what is it (inspyral)
inspyral you posted as i posted and just repeated what you said. oh well
Old Apr 20, 2002 | 02:19 PM
inspyral's Avatar
Default Re: code 41 what is it (simike)
jikespingleton
Nov 29, 2006 05:39 PM
MugenHonda
Jan 5, 2006 06:52 PM
aZnjCC
Oct 16, 2005 03:18 PM
KrazyMC
Apr 21, 2005 07:25 AM
UNDER PRESSURE
Jan 8, 2005 05:05 PM
