Help, swap not staring up
I just finished putting a D15B into my car. She turns over but is not firing up. Cam and crank are aligned. I can hear the fuel pump prime and the plugs are wet.
HELP ME OUT!
HELP ME OUT!
Re: Help, swap not staring up (Targa250R)
If the thermostat ground is off, the fuel pump wont prime, so its probably not it.
Sounds like your not getting spark.
Check your coil or ICM.
Mr. Badwrench
Re: Help, swap not staring up (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">If the thermostat ground is off, the fuel pump wont prime, so its probably not it.
Check your coil or ICM.</TD></TR></TABLE>
you're right my bad.
trav143
11
10-08-2008 10:58 AM
