HELP!! CRANKS BUT WONT START,NO FUEL AND SPARK !!
Grab a tester....start testing the Fuel pump wires and the dizzy wires...start from either the fuel pump/dizzy or from ECU...wherever spark/current stops....that might be the problem.
Re: (SinsEvil666)
dot hear the fuel pump prime thats the frist thing that i tride i put gas in the in tack thhin look for spark no spark it sucks
Re: (trav143)
my god please proof read and use the spell check. It hurts trying to read what you posted and I have no clear idea of what you have tested. First you say that you have spark then no fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav143 »</TD></TR><TR><TD CLASS="quote">yanked the motor and tranz put a new trans in will not sart</TD></TR></TABLE>
then you post this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav143 »</TD></TR><TR><TD CLASS="quote">dot hear the fuel pump prime thats the frist thing that i tride i put gas in the in tack thhin look for spark no spark it sucks</TD></TR></TABLE>
So are we to guess buy this that you have no fuel and no spark or is it spark and no fuel or fuel and no spark.
So first check to see if the fuel pump primes when you turn the key on, If you just pulled something??? make sure all the grounds are hooked up and connectors are plugged in.
then you post this
Re: (trav143)
Your timing belt might have snapped. Happened to my friends car. Open your oil cap and have someone crank your car. Look to see if your cams crank.
