help stuttering problem
here's the prob under light acceleration my car will stutter like its going to quit but when u get into the gas it cleans up. it also does this when u hold a steady rpm like when u are cruising on the highway. the cap, rotor & wires looked ok to me and i just replaced the plugs. the car is a 99 cx and i have the normal bolt ons with a z6 intake manifold swap. it is becoming progressively worse.
Re: help stuttering problem (sohc_boy)
i have the same problem, but i have a funny feeling it has something to do with my MSD ignition haveing no external coil for it. is it possable to fry my stock one if i JUST use the MSD SCI ignition?
Re: help stuttering problem (blackhatchy)
timing is stock and i already ripped the msd out thinking it was that. cap and rotor look ok, but i'm gonna change them tonite to see if it helps. i haven't chk'd the fuel filter yet, if it still doing it after i change the cap and rotor than i will prolly look at that next.
time out, did you have just the ignition on there??? no external coil /blaster pack or anything like that???
cuz we both seem to be having the same problem and just so happened to have the same parts.
Re: help stuttering problem (DOHC hatch ej)
no external coil, everything on the ignition is/was stock except for an msd box. i removed that thinking it might have been the problem but it still does the same thing.
try changing the whole cap and rotor assembly...i just did that yesterday to my h22 and it fixed it...feels alot smoother now too...my problem was pretty obvious tho because i had a lil oil in my cap
Re: (teameracer3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teameracer3 »</TD></TR><TR><TD CLASS="quote">try changing the whole cap and rotor assembly...i just did that yesterday to my h22 and it fixed it...feels alot smoother now too...my problem was pretty obvious tho because i had a lil oil in my cap</TD></TR></TABLE>
how much did that run you $$??
would it cost the same for a civic..and where did you get your stuff
Re: (N~FaMouSKhMerBoi)
just changed the cap and rotor, still doing it. the cap and rotor cost 26 dollars from advance. man i'm really getting annoyed that its still doing it i guess i'll try the fuel filter next.
THC07
11
11-10-2005 09:27 PM
slooogsr
07-05-2003 08:55 PM
