help with slave cylinder please!
ok i put on the new slave and im bleeding it and everything is good , the clutch is getting stiffer etc, im doing this for about 15 minutes....and then when i think its done i keep pumping it just to make sure its stiff and the boot on the slave fills up with fluid and looks like its gonna blow up the more i pump it, so i have NO choice but to bleed again and again and it wont stop looking like its gonna explode....is the o ring gone bad in the new slave already?// please help thanks
Re: help with slave cylinder please! (gtowni3)
what could have gone wrong, did i pump too many times?
the boot on the slave after about 5 pumps it looks like its gonna burst ,btw
Re: help with slave cylinder please! (bboylito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote">well what was it???</TD></TR></TABLE>
Re: help with slave cylinder please! (EE_Chris)
you don't have to pump the clutch pedal to bleed it..
you just open the bleeder screw on the slave cylinder and let gravity do its thing.
Re: help with slave cylinder please! (sidesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi »</TD></TR><TR><TD CLASS="quote">you don't have to pump the clutch pedal to bleed it..
Really? I understand it will drip out and ****, but I think pumping the clutch helps.
edit: To original poster....what was the problem?
Re: help with slave cylinder please! (boostedcivicsir)
The unit was probably just a defect. You should be able to pump it thousands of times. Just imagine how many times you pump it over 200,000 miles of city driving. A good one should hold up.
Go Tigers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtowni3 »</TD></TR><TR><TD CLASS="quote">i keep pumping it just to make sure its stiff and the boot on the slave fills up with fluid and looks like its gonna blow up the more i pump it.....</TD></TR></TABLE>
what exactly are you talking about here?
90babyblue
04-30-2004 03:43 AM
