HELP removing automatic transmission. its STUCK
D15B7....... The automatic transmissions prebably never been removed before and seems to be stuck or I don't know how to get it off. Starter is off, all the bolts have been removed that were connecting it to the block, and I pried the transmission about an inch away from the motor and can't get it any more.
What else is holding it on there!?!
Re: HELP removing automatic transmission. its STUCK (_crx)
If theres nothing else holding the tranny to the block just keep prying. If you already had it an inch away there isn't much more to go.
This motor/tranny is out of the engine bay already right?
Re: HELP removing automatic transmission. its STUCK (94_HATCH)
Yeah the motor's out (I should have mentioned that) .... Dude I've hit this thing with a 4 foot prybar and nothing. The tranny actually rotates on the crank but isn't coming off. WHAT THE HELL!
Pics tomorrow.
Pics tomorrow.
Re: (rogue420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">Are you sure u got all the little brackets off from the bottom of the motor?</TD></TR></TABLE>
I'm pretty sure..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rogue420 »</TD></TR><TR><TD CLASS="quote">r u sure that u removed the flexplate bolts? the bolts that connect the flexplate the torque converter.</TD></TR></TABLE>
That might be it. How do I spot the tq converter then? I will have pics of all this soon
I'm pretty sure..
Re: (_crx)
I think you have to remove the 8 bolts holding the torquw converter to the flywheel, you get those by doing one at a time then rotating the crank pully to get anther one exposed then do anther one and so forth, then it should come right off.
