Please Help, Frustrated Transmission Removal
Old Aug 5, 2006 | 03:00 PM
AccordVT's Avatar
Default Please Help, Frustrated Transmission Removal
94 Accord Dx 5Speed 4 dr
I am certin I got all the bolts off, the linkage off and all wires, everything The tranny still Won't seperate from the block. I took of the entire pass. side mount off butthe tranny just won't budge, I can pry the front open about a centimeter(between motor and tranny) but the top/bottom, and entire rear won't seperate at all. I have tried for days/hours, I am really tired and me and my dad are wicked stumped any help greatly appreciated
Old Aug 5, 2006 | 04:49 PM
AccordVT's Avatar
Default Re: Please Help, Frustrated Transmission Removal (AccordVT)
Anyone know why it's not comming off? I NEED the tranny to come off, I have got everything else i need off from it but the tranny is stuck in the car and i can't figure out why?
Old Aug 5, 2006 | 05:26 PM
Golferdude1977's Avatar
Just to make sure, if it is an automatic, my 97 had 4 bolts on top, and 5 on the bottom. The first time I pulled it, it was tight, but it sure does sound like there is a bolt somewhere hiding. I assume it isn't binding on the body somewhere?
Good luck...
Old Aug 5, 2006 | 08:09 PM
stumpyf4's Avatar
Did you remove the starter motor?
Old Aug 5, 2006 | 08:39 PM
AccordVT's Avatar
Default Re: Please Help, Frustrated Transmission Removal (stumpyf4)
yeah the starter motor is in the front of the tranny and the front pry's apart. I removed it. It feels alot like there is something major holding in the rear of the tranny (near the firewall side) but i have checked and looked and i can't find anything! it's so annoying and I have been trying at it for days. Do I need to do anything with the flywheel? Is there some weird bolt I can't find or a special tool i need to pull it off? Is there a technique to it or do I just pry at it?
Old Aug 5, 2006 | 09:55 PM
SuzukaBlueAP2's Avatar
Removing a transmission shouldn't be that difficult.
Usually there are more than 1 mount. So, make sure you've removed all connected mounts.
The starter has to be removed. (it seems as you've already done that)
Remove all bell housing bolts. I don't know how many there are on the Accord transmission.
Remove any electrical harnesses that are connected to the transmission.
Disconnected shift linkage.
Remove axles.
Don't forget to drain it first....ha ha.
That should be all.
Old Aug 5, 2006 | 11:19 PM
white90crxhf's Avatar
is there a bolt on the engine side of the transmission? i know my dastardly crx transmission had one. don't forget it.
Old Aug 5, 2006 | 11:25 PM
AccordVT's Avatar
Default Re: Please Help, Frustrated Transmission Removal (SuzukaBlueAP2)
The fact that you said "Removing a transmission shouldn't be that difficult" scares me. I thought the same thing. When I pry, I use a huge metal pole i found and slide it in the front between the motor mount and the tranny housing on the bottom side. It comes apart fairly easily but only in the front and it will only open up to a certain point, then it stops comming apart, and as soon as I stop prying(stop pushing on the pole)....the tranny springs back onto the motor. I really want to say that there is something holding it on (mount, bolt,something caught) but it looks totally clear. I got the axles out and the intermediate shaft. It seems like if I could pry from the back somewhere it might come apart but i have tried the best I can (impossible to get a pry bar anywhere back there) but it won't come off, won't even slightly seperate i the lower/upper 3/4 of the tranny. Any ideas? I'm giving it another day or two and then I am gonna just pull the motor and transmission as one peice and try to seperate afterwards.
Old Aug 5, 2006 | 11:38 PM
91SiZ6's Avatar
I'd almost bet that you missed a bolt on the backside. If not, time to bust out the BFRH (big ******* rubber hammer).
Old Aug 6, 2006 | 08:39 AM
Default Re: (91SiZ6)
Just give the whole area a look over. I'm sure you'll find whatever it is that's keeping you from removing it.
Do you have an extra jack that you can put under the transmission to take some stress off of it? That might help..
Old Aug 8, 2006 | 03:46 AM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordVT &raquo;</TD></TR><TR><TD CLASS="quote">The fact that you said "Removing a transmission shouldn't be that difficult" scares me. I thought the same thing. When I pry, I use a huge metal pole i found and slide it in the front between the motor mount and the tranny housing on the bottom side. It comes apart fairly easily but only in the front and it will only open up to a certain point, then it stops comming apart, and as soon as I stop prying(stop pushing on the pole)....the tranny springs back onto the motor. I really want to say that there is something holding it on (mount, bolt,something </TD></TR></TABLE>
That sounds eerily identical to a post I made when I first tried to remove a tranny . Turns out I had missed the opposing bolt on the firewall side of the tranny. Make sure you get that bolt - it faces the passenger side of the car, not the driver side like the rest of the bolts. Also, don't forget the bolts by the flywheel dust cover.
JJ's civic
13
May 4, 2008 09:25 AM
tallblondkid
Aug 11, 2004 01:32 AM
Unjockable
20
Nov 10, 2003 02:36 PM
Rpc07
Aug 28, 2003 10:10 PM
Heinz57
May 26, 2003 12:34 PM
