help no spark
Re: help no spark (WICKEDII)
I just had a similar problem, it was the module. But mine is a stock 92 sohc vtec. Was your engine running before or did you just do a swap?
Re: help no spark (deepnite)
when everything seems ok..its usually the alternator
check your ecu, make sure it's plugged in properly, the fuse is ok, then check the ignition signal from the ecu... just make your way down the line till you figure out what is wrong
Re: help no spark (blackteg)
I'm having the same problem but with a stock 89 CRX SI. Which module are you guys talking about? I've check the coil with an ohm meter and it is within the correct params. I've replaced the rotor and cap. Still no spark. The car actually died while driving on the freeway!!!
tyy checkin the icm (ignition control module). its located in the distibutor, its the one with 4 wires connected to it. try that,trust me thats the problem.
Re: help no spark (civteg)
I replaced the ignition control module. It didn't work. Could the coil still be bad even though the impedence is within the correct params? It had a lot of carbon deposits inside the distributor.
thekooler
08-02-2011 08:54 PM
