help my civic hatch dx won't start
my car has a little oil leak and da last time i done anything to it before it died was put more oil in it and now the oil thing looks like there is more oil in there. i tried to drain sum out but the car still won't start. it cranks but it doesn't run...I dunt kno wut to do...please help any mechanics out there...i've checked the fuel pump, fuel lines, rail, injector, filter, so i dunt think it's the fuel equipments, might be distributor cap or wires. i just put in new spark plugs tho. battery is low to but put new one in and still like it so help....wels i can't think of anything else but please do help.
Re: help my civic hatch dx won't start (Nameless)
yeh dat sounds like problem. U need 2 git down 2 da local hoduh place and get dat mechanik dood 2 check dat ****.
Re: help my civic hatch dx won't start (ArinX)
my friend had that same problem. it turned out to be his ecu though, it was bad. if it turns out to be your ecu, i have one that i will sell you.
93hb
93hb
New User
Re: help my civic hatch dx won't start (93hb)
i had almost the same prob with my dx, it burned oil bad, and it would crank kinda, but then it would cut, so i thought it was electrical, but turns out it is really really bad :< only 2 of my cylinders were getting compression, the otner 2 were flat at 0.
What language was that again??
Accordboy27
03-07-2006 09:56 AM
whitemike1644
28
12-14-2004 08:31 AM
