Won't Start
Old Dec 4, 2008 | 01:19 PM
Candzi's Avatar
Default Won't Start
I have come across a 1993 Honda Civic that someone is selling for dirt cheap because it won't start. The car has been stored for just over a year, I'm thinking that the problem could be really simple. Other than a dead battery, what else could potentially be the reason it won't start now when it ran fine before it was stored. What should I look for when I go take a look at it?
Thanks
C.
Old Dec 4, 2008 | 10:51 PM
mouab18c1's Avatar
jump start that sucker if not lucj....check for fuel and spark.......no spark then check the distributor, spark plugs, wires..no fuel then check fuel pump ecu, fuses, injectors, main relay under dash
Old Dec 5, 2008 | 02:39 PM
philafelman's Avatar
cylinders might be washed....try putting a couple drops of oil in each spark plug hole then start it....it will smoke like crazy for a lil bit though as the oil burns....the battery is probably the culprit though.
Old Dec 6, 2008 | 11:49 AM
JDM90CB7's Avatar
Default Won't start
If no fuel, check the fuel filter, they can clog after sitting for a while.
hamburgler
Aug 21, 2011 10:23 AM
Phantastic
May 28, 2010 03:15 PM
feava510
Feb 15, 2009 10:59 AM
vinuneuro
Oct 12, 2006 05:44 AM
civic efb16
Aug 8, 2005 09:00 PM
