help me
New User
help me
2000 B16 in a eg hatch runs fine idles fine if i step on full throttle in neutral revs out at like 3500-4000. if driving i rev it slowly up, its fine step on it a full throttle breaks up dies on its face ... what you think
Re: help me
Are you saying that if you floor it in neutral, the RPM doesn't go higher than 4000? Check the valve and ignition timing. If they're ok, check the MAP sensor voltage.
Re: help me
The TPS output voltage should be about .40-.45v with the engine off and the key in the ON position. While checking the MAP, you might as well make sure the TPS is ok.
civicEX1995
68
01-13-2012 11:15 AM
