Help - Identify This Motor
Old 01-12-2008, 11:29 AM
Filippo's Avatar
Default Help - Identify This Motor
Hey tech's, bought a new 94 civic hatch today for parts, came with this motor. Definitely a swap but unsure what exact motor type it is. Need your helps guys, thanks :D
*also* if you could tell me the specs of the motor, that would be greatly appreciated*
* i feel so dumb *
haha
Old 01-12-2008, 11:31 AM
silentbeatz's Avatar
Old 01-12-2008, 11:34 AM
Dramier's Avatar
Default Re: Help - Identify This Motor (Filippo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Filippo &raquo;</TD></TR><TR><TD CLASS="quote">Hey tech's, bought a new 94 civic hatch today for parts, came with this motor. Definitely a swap but unsure what exact motor type it is. Need your helps guys, thanks :D
* i feel so dumb *
haha
Looks like a factory D15B7 or D15Z1 MPFI motor. Which would be stock for that car, not a swap.
Old 01-12-2008, 11:36 AM
Filippo's Avatar
Default Re: (silentbeatz)
fixed the pic link**
Old 01-12-2008, 11:37 AM
Filippo's Avatar
Default Re: (Filippo)
i meant it wasnt the original motor that was in the car when produced
Old 01-12-2008, 11:44 AM
BlueIntegraBoy's Avatar
Looks like a D16A6
Copied from Wikipedia:
Found in:
* 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
* 1990-1991 Honda Civic EX Sedan
* 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
* 1989-1996 Rover 216/416 GSi (UK/Europe)
o Displacement : 1590 cm³
o Bore and Stroke : 75 mm X 90 mm
o Compression : 9.1:1
o Power : 115 hp (86 kW) @ 5600 rpm & 95 ft·lbf @ 3,800 rpm, redline 6500 rpm (USA)
+ Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108
o Valvetrain : SOHC
o Fuel Control : OBD-0 four-point PGM-FI
o Head Code : PM3
o Piston Code : PM6
Old 01-12-2008, 11:55 AM
Filippo's Avatar
now that just threw me off course integraboy i dont know who to believe haha
any other opinions folks?
Old 01-12-2008, 11:56 AM
steerh67's Avatar
look for the casting on the block, then you'll know for sure what you have, but to go along with the others, that does look like a factory d
Old 01-12-2008, 11:58 AM
LwdJdmR's Avatar
Default Re: Help - Identify This Motor (steerh67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steerh67 &raquo;</TD></TR><TR><TD CLASS="quote">look for the casting on the block, then you'll know for sure what you have, but to go along with the others, that does look like a factory d</TD></TR></TABLE>
X2
Old 01-12-2008, 11:59 AM
Filippo's Avatar
i did... no luck but maybe i've had one too many to the head lol, im gonna keep an eye out on this thread for a confident answer lol.. thanks people
Old 01-12-2008, 12:07 PM
Well, first off, it has a PGM-FI on the intake manifold. This only came on the OBD0 engines. Any 92-95 Civic engine does not have this on the manifold.
Plus, if you search D16A6 in the H-T marketplace and Yahoo Images, you get the same looking motor as the one you posted.
Here's an image of a D16A6
http://cgi.ebay.com/ebaymotors...l1247
Old 01-12-2008, 12:10 PM
Filippo's Avatar
Default Re: Help - Identify This Motor (BlueIntegraBoy)
Thanks Blueintegraboy.. greatly appreciated!!
Old 01-12-2008, 12:12 PM
Looks the same to me...
Old 01-12-2008, 12:13 PM
gsrhatch2356's Avatar
there is a stamp right by the trans which tells exactly what motor it is!!
Old 01-12-2008, 12:17 PM
Hanmin's Avatar
Old 01-12-2008, 12:36 PM
redlinexd's Avatar
its most likley a D15B, looks like the one on my friend's DX hatch
Old 01-12-2008, 12:57 PM
Default Re: (redlinexd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinexd &raquo;</TD></TR><TR><TD CLASS="quote">its most likley a D15B, looks like the one on my friend's DX hatch</TD></TR></TABLE>
It's not a D15B (SOHC VTEC). There isn't a VTEC solenoid.
Like I said above, it's most likely a D16A6.
Old 01-12-2008, 01:03 PM
importdreamer's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
I'm voting for d16 a6 based on the pgmfi intake mani. And the valve cover is the same as the one out of my boys 91 crx si.
Old 01-12-2008, 02:46 PM
SoHcEK99's Avatar
Default Re: (importdreamer)
Just look at the sticker on the timing belt/cam gear cover. It should have the same code on it that the block has stamped into it.
Old 01-12-2008, 02:52 PM
be professional
Targa250R's Avatar
The intake manifold and timing belt cover are from a D16A6 or pre-OBD SOHC ZC. Valve cover is pre-'94, if not pre-'92. The distributor is OBD-1 (two gray plugs).
I'm betting it's a D16A6 converted to OBD-1. Check the block stamp to confirm.
1337knub
05-21-2007 09:08 AM
slowpokecivic
12
04-20-2006 08:21 PM
integradummy91
08-29-2003 09:28 PM
Quick Reply: Help - Identify This Motor
