help! i need help with brake conversion
i have 94+ integra brakes and i installed them on my 95 si hatchback. i changed the setup from the upper control arm to the lower tie rod. so i used my stock brake lines. but i have a big problem. after my brother and i did the whole brake conversion, my brakes don't hold resistance anymore. when my engine isn't running a little bit of pressure develops if i pump the brakes, but as soon as i turn the key the brake pedal drops to the floor. i mean completely and it isn't holding any pressure. please help me. i doubt it is because i used my stock brake lines because someone on here did the same brake conversion on his 92-95 cx hatchback and he said that he could notice the increased braking power. please let me know what we did wrong or why my brakes are not holding any resistance.
Re: help! i need help with brake conversion (globlctzn)
yeah that is what i think it is. because i did bleed teh system but i think i may have done it wrong. i started from the passenger rear then to the driver's front and then to the driver's rear and then to the passenger front. all i did was have someone watch the fluid level and she kept filling it to make sure the fluid didn't run out completely, then i had someone in the car to pump the brakes and all i did was loosen the bleed bolt and then have then pump it like five times then i tightened the bleed bolt again. how should i have done it?
Re: help! i need help with brake conversion (civicjdmgsr)
thats the wrong way to bleed the brakes, i think it's right rear, left rear, right front, left front. or something like that, try to search for it, should have been covered before. good luck.
bboyjimpy
04-25-2010 07:30 AM
TedR719
09-10-2004 03:59 PM
