Help rear disc brake swap.
Ok, I need some help i bleeded my brakes i used integra brake lines and ebrake cables.. my ebrake cables seem kinda long so i adjust it but it doesnt seem to be locking well.. ok well after i bleeded my brakes i drove my car and my pedal hits stright to the ground..after about 5 seconds i stop but slowly... did i do something wrong? i havent changed the Master cyclinder or the brakebooster but somebody told me it doesnt matter... and the prop vavle wasnt changed either.. can anybody eles help me out? maybe somebody that didnt change their mc and bb and pv?
any info would really help thanks!
Re: (ekx4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekx4 »</TD></TR><TR><TD CLASS="quote">how do i make sure there are no airs in the brake line?</TD></TR></TABLE>
you bleed it and look at the fluid coming out of it is not air. best way to do it, is submerge the hose into a clear jar filled with brake fluid and attach the other end to the nipple of the brake caliper. pump the brakes until you don't see anymore air coming out of the nipple then tighten it with hose still submerge in the jar. do that to each corner starting from the left rear corner then, right front then, right rear, and finally left front.
btw sounds like you need this to make sure you do it right in the first place: http://www.helminc.com
Re: (ICEDOWT)
so i changed my master cylinder and rebleeded the system, but something still seems to be wrong... when the car isnt started the pedel is hard, once the car is started it drops dead to the floor... i got the mc off a 99-00 civic si.
bleeded my brakes about 8 times...
