e brake problems with integra brake conversion
Ok i need to attempt to hooking up my ebrake today after not having it hooked up for like a month since my disk brake swap. I have a 94 civic dx with a gsr conversion.. The brakes work fine but the e brake cables do not reach all the way to the holes, do I just need to pull them up and install it, also one reaches further up (the passernger side) than the other one (drivers side)
Any tips?
Any tips?
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">u need disc brake ebrake cables.</TD></TR></TABLE>
They are the ones that came with the rear brakes, so they are disc brake e brake cables.
H-T Poker champion
Re: (TedR719)
jack up the car and make sure they arnt snagged on anything.. there is a specific way they have to travel to the cabin of the car in order to be long enough... i can't really explain it, you will just have to figure that part out on your own.
Re: (Hatchy-Ownzjo0)
I made sure that I bolted them up the same way the others where put on. Maybe I could check again, other than that has anyone eles had this problem?
Re: (TedR719)
Had that problem on my buddy's EK. I put a complete set of Si-R disk brakes on his car and the right-rear e-brake cable reached further up than the left-rear e-brake cable. But I still got it there. It just pulls on the right-rear far forward more than the left-rear. And the cable runs through the undercarriage the corret way. The brackets of the e-brake cable are bolted underneath on the factory holes/spots.
Re: (TallAssFilipino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallAssFilipino »</TD></TR><TR><TD CLASS="quote">Had that problem on my buddy's EK. I put a complete set of Si-R disk brakes on his car and the right-rear e-brake cable reached further up than the left-rear e-brake cable. But I still got it there. It just pulls on the right-rear far forward more than the left-rear. And the cable runs through the undercarriage the corret way. The brackets of the e-brake cable are bolted underneath on the factory holes/spots.</TD></TR></TABLE>
so just pull those lines up and I should be ok, what about the braket that goes right behind where it hooks up, did you get that to bolt down as well.
Thanks for the info!
Re: (TedR719)
I heard that since the lines are short that it will grind down the pads (which would make sense if I have to force them in like that) , and someone who had this problem got 94-95 Si e brake cables and it works perfectly for him, this is also on a hatch, is there any difference with those brake cables (hatch vs coupe) they way the run under the car.
Re: (TedR719)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TedR719 »</TD></TR><TR><TD CLASS="quote">I heard that since the lines are short that it will grind down the pads (which would make sense if I have to force them in like that) , and someone who had this problem got 94-95 Si e brake cables and it works perfectly for him, this is also on a hatch, is there any difference with those brake cables (hatch vs coupe) they way the run under the car.</TD></TR></TABLE>
Everything was bolted up correctly and yes every part was there. My buddy's car was a 99/00 EK hatch. The brakes I installed on his car was from a 91-95 EG Si-R hatch. The e-brake cables were the original/stock cables. But yeah, it's something you want to fix. If you ever do, somehow, end up having to use the e-brakes while the car is mobile, then it may cause you to fishtail.
