Help headlights get brighter when i gas car!
Re: Help headlights get brighter when i gas car! (ej6g)
your alternator is weak its not working properly and there fore its not supplying the power to make the bulbs bright as when you gas it when you gas it then it spins faster and more power is made
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97exd16 »</TD></TR><TR><TD CLASS="quote">crappy alternator</TD></TR></TABLE>
check your Ground points, especially the underhood fuse box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6g »</TD></TR><TR><TD CLASS="quote">As said above only when i gas it lights get brighter then i let off it gets a lil dimmer anybody know what can cause this?</TD></TR></TABLE>
might be ur battery too..change it too! not that much, and cost less than the alt....how much miles are on the car??
If it not a major change in the brightness, don't worry about it. It is pretty normal. With alot of the cars I've owned, I've noticed the headlights dim a tiny bit at idle.
If its a big difference, then check your grounds, alternator, and consider possibly replacing the battery as well, if its old.
Re: Help headlights get brighter when i gas car! (Apologetic Theory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apologetic Theory »</TD></TR><TR><TD CLASS="quote">If it not a major change in the brightness, don't worry about it. It is pretty normal. With alot of the cars I've owned, I've noticed the headlights dim a tiny bit at idle.
If its a big difference, then check your grounds, alternator, and consider possibly replacing the battery as well, if its old.</TD></TR></TABLE>
what he said.
things that will cause the lights dim at idle.
ground wires
battery - especially if it cranks a little slower
alternator - doubtful it's totally bad though if the lights brighten up when you accelerate.
check in that order.
what he said.
ground wires
Imperious: Mod of Valor
Ground wires could definitely effect it, as well as bad battery. Alternator is the big thing though, check all the small easy stuff first, and then check the alternator.
Re: Help headlights get brighter when i gas car! (JDM-EJ1)
if your alternator is bad, then you have worse things to worry about than if your engine is losing power, like "will my car start the next time i turn the key?"
Re: Help headlights get brighter when i gas car! (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Ground wires could definitely effect it, as well as bad battery. Alternator is the big thing though, check all the small easy stuff first, and then check the alternator.</TD></TR></TABLE>
Re: Help headlights get brighter when i gas car! (Nyceguy17)
thanx guys imma check all my grounds.i had the alternater checked by a repair shop they said it was all good.also it dims jus a lil bit but nothin major.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6g »</TD></TR><TR><TD CLASS="quote">thanx guys imma check all my grounds.i had the alternater checked by a repair shop they said it was all good.also it dims jus a lil bit but nothin major. </TD></TR></TABLE>
Awesome, if it's not the alternator. It's definitely bad grounds, check all your grounds, if they're faulty, replace them.
vlc92189
10
09-24-2007 08:20 PM
GRAVEDIGGER
22
10-11-2003 11:15 PM
