HELP CEL TPS pops up all the time after VTEC
New User
i have a 2000 honda civic with an OBD2 GSR and an ecu jumper. i have a p72 OBD1 computer.. everything is fine unless i punch the gas and after vtec pops the cel comes on and its the TPS. i turn the ignition off and on to reset it then punch the gas again but still CEL pops up after vtec and its TPS.....................any suggestions Thanks
Re: HELP CEL TPS pops up all the time after VTEC
recalibrate your tps sensor.... search it if u dont know how, if that does not solve the problem, then your tps requires replacement due to a deadspot on the sensor somewhere near full throttle apparently
like he said try and recalibrate your tps, but i had the same problem after hiting vtec it would throw a cel for the tps sensor, after awhile of that happening a few months the cel just stayed on for the tps sensor, I replaced it with a blox tps sensor and it works fine now no problems, i belive your tps sensor to be on its last legs.
same here recalibrate it, .5v closed and 4.5v WOT if you didnt know it means wide open throttle, i just did mines today, and trust me it makes a diff, your going to need a volt ohm meter, harbor freight has them for 1.99
