help car is in limp mode
i have a 93 ex civic with a 1995 gsr swap i am running the p72 but when i did the swap i didnt wire the knock sensor or the aib butterflies but i wired the aib to the ecu and a 12v source but car still doesnt drive how it is suspose to if i was to get on it hard the car would basically shut down
sry but everyone is not perfect
Modified by rkn527 at 3:23 AM 5/18/2004
1 Post
Re: help car is in limp mode (rkn527)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkn527 »</TD></TR><TR><TD CLASS="quote">i have a 93 ex civic with a 1995 gsr swap i am running the p72 but when i did the swap i didnt wire the know sensor or the aib butterflies but i wired the aib to the ecu and a 12v source but car still doesnt drive how it is suspose to</TD></TR></TABLE>
a little too vague, buddy, it's not in limp mode if the car ain't running
oh, and you might want to edit your post, seeing as how your grammar is ****
Re: help car is in limp mode (Kamin)
OK PUT IT THIS WAY WHEN I GET ON THE CAR IT BOGS DOWN THEN IT GOES DOES ANY ONE KNOW WHAT COULD BE WRONG SINCE SOME H-T MEMBERS ARE ********
Re: help car is in limp mode (Kangaroo_Boy)
IT IS THROWING A CODE I KNOW BY THE KNOCK SENSOR NOT BEING CONNECTED THERE WILL BE A CODE FOR THAT BUT I TRIED TO LOOK FOR THAT LITTLE GREY HARNESS BY THE GLOVE BOX BUT NOTHING THERE IT RUNS GOOD SOMETIME BUT IT RUNS LIKE **** SOMETIMES TO. I WAS TOLD IT COULD BE THE KNOCK SENSOR SINCE IT IS NOT CONNECTED IT IS PULLING TIMING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkn527 »</TD></TR><TR><TD CLASS="quote">IT IS THROWING A CODE I KNOW BY THE KNOCK SENSOR NOT BEING CONNECTED THERE WILL BE A CODE FOR THAT BUT I TRIED TO LOOK FOR THAT LITTLE GREY HARNESS BY THE GLOVE BOX BUT NOTHING THERE IT RUNS GOOD SOMETIME BUT IT RUNS LIKE **** SOMETIMES TO. I WAS TOLD IT COULD BE THE KNOCK SENSOR SINCE IT IS NOT CONNECTED IT IS PULLING TIMING</TD></TR></TABLE>
your caps lock is on.
and connect your knock sensor.
NotNew
15
08-31-2008 10:13 PM
pnltnc
04-11-2004 04:41 PM
