GSR swap question
GSR swap question
I recently put a 97 GSR motor in my 94 ex. Its not pulling hard past 7300rpm sounds like its floating the valves or something. I used a p30 ecu and ran the knock sensor wire and switched the A20 wire to A17 on the ecu and put 12v key power to the IAB. I put new NGK's, cap,rotor,and wires. Any other suggestions
Re: GSR swap question (zzZZzzleeperCX)
since you put a 12v source to your iab's
and you dont have the correct ecu to run it.
your iab's are probably not opening up at the right rpm.
effecting performance.
B18Cej1
18
03-02-2004 03:33 PM
