BSR SWAP
gsr SWAP
i put a 95 gsr swap in my 93 coupe ex but i am getting the engine light on as i drive the car i was told that i had to wire a knock sensor and something else can someone help me out.
i would like to know can a ls throttle cable work for the swap and does the throttle cable run on the top or the bottom
Modified by rkn527 at 7:31 AM 12/1/2003
Re: BSR SWAP (rkn527)
if your using the p72 ecu then you gotta run the knock sensor (i believe its pink/blue) wire to d3 on the ecu and switch a20 to a17 (red wire) for the butterflys.
NotNew
15
08-31-2008 10:13 PM
