HELP bearing!!
HELP bearing!!
are the d15 bearing the same to a d16 bearing that are around the crank. stock ones.. question is could i swap bearing out. on the block.
jose
jose
Re: HELP bearing!! (coupedragracing)
to be honest. I would not recommend it. doesn't matter if they are compatible with each other or not. I would correspond with what color codes you have on the block, and get new bearings.
Fishy_hondaman
Engine Machining & Assembly
09-18-2016 10:05 PM
MARVNVRAM
12-19-2007 05:26 AM
