Quick Bearing Questions
Old Mar 20, 2005 | 07:22 PM
THEUSED's Avatar
Default Quick Bearing Questions
Alright Im about to order my bearings from the codes on the block and crank(this is the first time this block has been apart), But I was reading an old post that said you should platigauge your stock bearings to see if they were in spec or something along the lines of that, so should really matter if I order my bearings using the codes right(then plastigauging them just to be sure)since my Block has never been apart right?
One last thing I was going to order my bearings through http://acuraautomotiveparts.org but they dont have the codes for bearings with colors, they use letters, Bearing A, B, C, D, E, F, G, so umm whats the deal with that, which colors match each letter?
Thanks
Old Mar 20, 2005 | 11:00 PM
THEUSED's Avatar
Help Me
Old Mar 20, 2005 | 11:24 PM
ekb16's Avatar
are you talkin about the main bearing or rod bearing?? i dont think the quick release bearing is in the engine..i think thats ont he tranny...
Old Mar 21, 2005 | 12:29 AM
THEUSED's Avatar
Im talking about the Rods and Mains
Old Mar 21, 2005 | 08:26 AM
civic-4-ges's Avatar
Default Re: (THEUSED)
You should order the size according to your block/crank/rods, then plastigauge when you receive them
If you gauge your existing bearings, they will not read correctly...they are worn.
Old Mar 21, 2005 | 11:06 AM
THEUSED's Avatar
Yeah thats my plan, I just happened to read a post that said otherwise......Any thoughts on my 2nd question ?
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
goat86
Apr 19, 2014 12:00 AM
killerpenguin21
Jul 12, 2006 07:20 AM
dt4life
Jul 30, 2004 06:24 PM
