Spun Bearing
Old Jul 2, 2003 | 06:53 PM
carblegal's Avatar
Default Spun Bearing
I was looking into buying a used block, and the seller said that he thinks he has a spun bearing.
What are the symptoms of a spun bearing? Could the motor run with a spun bearing?
How would you repair a motor with a spun bearing? I assume that you will have to remachine the block/rod and crank.
Old Jul 2, 2003 | 07:32 PM
NSX Bob's Avatar
New User
Default Re: Spun Bearing (carblegal)
Best case scenario? You need new bearings.
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
ziggy3784
Apr 30, 2009 07:48 AM
SuckMyDOHC
Jun 15, 2008 11:29 AM
HickamHatch
Dec 17, 2005 04:10 PM
jdmcivicferio
Mar 16, 2003 06:54 AM
