height issues b18c5 hood?
i had a problem while building my crx with the C5 in height. i was curious if there is any issues with hood cleaence with the del sol?
i did search. civics came up ( b18c5 fit:searched)
Re: height issues b18c5 hood? (rewerbcrx)
Only problems i know of is with old school VIS hoods. As far as i know they change the design so they do not hit anymore. Other then that you should be good.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">any other def answers?</TD></TR></TABLE>
Check the 88-91 civic/crx forum.
Re: height issues b18c5 hood? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
Check the 88-91 civic/crx forum.</TD></TR></TABLE>
OKAY... pointless reply... i already stated i know about the crx and the b18c5.... DUh
i need to know def answers to the del sol... i already know the hieght differences i put a b18c5 in my crx!
im running a turboed lsvtec in my del sol.. it came with the b16.. i had a little rubbing of the valve cover on the hood very minor i just took washers and longer bolts for my hood hinge's and it solved it.. i dont know if you want a lifted hood though
Re: height issues b18c5 hood? (del_slow420)
thank you ... that is exactly what i wanted to here... that means the b18c5 would REALLY rub... and i def don't want a raised hood...
does anyone know if they make a CF hood for the del sol that raises up... <U>like</U> the JDM up bump from VIS for the crx
1 Post
Re: height issues b18c5 hood? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Only problems i know of is with old school VIS hoods. As far as i know they change the design so they do not hit anymore. Other then that you should be good. </TD></TR></TABLE>
yup, i had a double sided VIS and that thing fell victim to my motor going through it... I wanted to cry..
Re: height issues b18c5 hood? (Uxi)
so for the "old" vis hods its a no go... do they make a bumped up hood or not?
more help on this would be great... for future swappers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">thank you ... that is exactly what i wanted to here... that means the b18c5 would REALLY rub... and i def don't want a raised hood...
No, b16's do not rub they come with that motor from the factory with plenty of clearance.
Re: height issues b18c5 hood? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
No, b16's do not rub they come with that motor from the factory with plenty of clearance. </TD></TR></TABLE>
the b18c5 head is 8mm taller than the b16 you obviously don't know whatyour talking about
the b18c5 head is 8mm taller than the b16 you obviously don't know whatyour talking about</TD></TR></TABLE>
I wasn't talking about the B18c5 I was talking about the B16 you quoted the previous post about his setup rubbing. I am very aware the height difference between the motors, I was only clarifiying his statement saying there is plenty of clearance with the stock B16. Learn to read dumbass if your going to ask people for help and be a *** to them.
obviosly your reply has nothing to do with the OP... and i don't care one bit about a b16... try to keep up and stay on topic...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">obviosly your reply has nothing to do with the OP... and i don't care one bit about a b16... try to keep up and stay on topic...</TD></TR></TABLE>
quit being a *****. His post is on topic because he was correcting previous info that was incorrect. A b16 came factory, so trust me, it will fit with plently of room, so if you use a stock hood with a b18, it should fit. There's your answer dumbass.
Re: (instrument)
i would like to talk to someone that has a c5 in their del sol with a CF hood. instead of spectators guessing. thank you
PINKS
10
05-15-2006 04:39 PM
