Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Keep getting p0132 code
Old Sep 19, 2024 | 06:18 AM
Nightpoacher's Avatar
Default Keep getting p0132 code
Hello! Friend gave me a 01 civic ex.
changed the thermostat, cam sensor, plugs, air filter, full fluid change, gas cap all Honda oem parts.. car sat for 7 yrs. Got a p0132 code so changed the upstream O2 sensor with denso and oem IAT sensor. I get about 100 miles or so and code comes back. Same p0132. Checked wiring and looks good. Any thoughts!?
Old Sep 19, 2024 | 11:27 AM
hondamark35's Avatar
Default Re: Keep getting p0132 code
other symptoms?
how well does it drive?
what plugs did you put in it?
Old Sep 19, 2024 | 12:19 PM
Originally Posted by hondamark35
other symptoms?
hey mark.. drives great. Smooth and strong. No other symptoms at all. Used the recommended iridium plug
happens every 100mi or so
Old Sep 23, 2024 | 12:16 PM
Any help would be great
Old Sep 24, 2024 | 04:24 AM
either you're running rich, or the ECU thinks you are...
your first step should be determining which of those it is. This can be a challenge.
if the ECU thinks you are but you're not really, it's probably a wiring issue or a bad ECU. probably not too bad to fix complexity-wise.
if you are running rich, figure out why. This can be a challenge.
you'll want one of these if you don't have one yet. $75 is a pretty good deal
a full-featured OBD-II scanner at a minimum. bi-directional may be better, but this is pre-CANBUS so maybe not. Foxwell and Autel are both good brands for "home mechanics"
macasoft
Honda Civic (2006 - 2015)
May 17, 2021 06:46 PM
rxbahamut
Feb 1, 2013 09:11 PM
S4gazm
12
Mar 13, 2007 07:36 PM
JDM_EK_621
May 24, 2006 10:31 AM
silentblackhat
Mar 8, 2005 12:48 AM
