headlights
headlights
honda 1994 civic lx 2 door, passenger headlight comes on sometime, blinker and parking light work. seems like there is a connection or wiring problem, maybe a fuse, cant figure it out
Re: headlights
If it only affects one beam, try a new bulb first. Really any time that something on a car doesn't light up, try a new bulb.
Wiggle the plug on the back of the bulb with the light switch on to see if that makes it go on and off. May need a new plug.
There are 4 fuses under the dash-- one for each side and each beam. Wiggle them as well. A blown fuse would be out all the time though.
Re: headlights
Thanx, the high beam indicator light on the dashboard stays on too, tried to wiggle and disconnected the wire, no luck , when i turn the lights on the dash lights also dim
Deafkid2005
04-22-2014 07:51 AM
crx_253
12-27-2008 07:02 PM
