Headlight Streaks / groves
Old 07-18-2005, 11:37 PM
deadlock32's Avatar
Default Headlight Streaks / groves
This is similar to the hazy headlight question.
On majority of the honda 2000 and below the headlights are not clear, rather they have lines/groves from the factory that distort and clouds the lights.
My question is that since no after market headlights are made for delsols and im not wasting my money to tailor another hondas lights to it, is it possible to remove the clear part of the headlight and 'sand' away all the groves and such and end up with a crystal clear headlight cover? [i know how to remove the lense... oven, just wondering if there is an easy way to clear them]
Old 07-19-2005, 12:04 AM
built562's Avatar
Default Re: Headlight Streaks / groves (deadlock32)
you might be able to do it, i have taken all the molding marks from my s10 taillights. the little letters on the brake lights. i took them down with sandpaper starting with 400 grit then working my way up to 2000 and using a polish and wax with a buffer and they are smooth. now i dont know if this will work on a clear lens but you might want to get one del sol light from ebay or something or a junkyard and try it out
Old 07-19-2005, 12:37 AM
Outrun's Avatar
Default Re: Headlight Streaks / groves (built562)
Those ridges help in the distribution of light.
Old 07-19-2005, 12:51 AM
deadlock32's Avatar
Default Re: Headlight Streaks / groves (Outrun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun &raquo;</TD></TR><TR><TD CLASS="quote">Those ridges help in the distribution of light.</TD></TR></TABLE>
yeah I know, im sure that it light will be just fine w/o them and if not well, i'll be able to tell you guys how much it sux and not to do it.
Old 07-19-2005, 02:37 AM
Outrun's Avatar
If IL has yearly inspections that include headlight inspections you may want to keep the nipples.
Old 07-19-2005, 11:50 AM
deadlock32's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun &raquo;</TD></TR><TR><TD CLASS="quote">If IL has yearly inspections that include headlight inspections you may want to keep the nipples.</TD></TR></TABLE>
ok, fine. Remember to also answer the questions. I well aware of what can happen by removing the oem groves in the lights, I am wondering if its even possible to remove them.
Old 07-19-2005, 12:00 PM
Outrun's Avatar
You can remove the grooves while still keeping the nipples. If IL does not do headlight inspections then you can remove the nipples too. But it may be harder to remove the nipples.
What you should do is find some old headlights from a junkyard and practice removing the grooves.
Old 07-19-2005, 12:11 PM
deadlock32's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun &raquo;</TD></TR><TR><TD CLASS="quote">You can remove the grooves while still keeping the nipples. If IL does not do headlight inspections then you can remove the nipples too. But it may be harder to remove the nipples.
What you should do is find some old headlights from a junkyard and practice removing the grooves.</TD></TR></TABLE>
thanks, i've got zero problems with the nipples, just want the majority of the headlight cover to be clear. thanks
Old 07-19-2005, 12:56 PM
B-twentyVTEC's Avatar
bump for this guy!
tArebelpinoy
09-03-2008 06:06 PM
92piece
06-16-2006 11:45 AM
Curtis2kul
11
02-16-2004 02:54 AM
Dc2 Powered
11-29-2003 07:31 AM
Quick Reply: Headlight Streaks / groves
