Help need some timing belt info...put timing belt on now car won't start at all?
So here is the situtation. I just put on a new timing belt, did a valve adjustment and the car started to bog real bad. Now the car won't start at all now? There's fuel delivered and spark, the crank will turn over but the car will not start? Do you think that the TDC is not aligned right? I need some help fast. I'm so stressing. If anyone has any idea's that would be great.
Thanks,
h46it.
Thanks,
h46it.
Re: Help need some timing belt info...put timing belt on now car won't start at all? (h46it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h46it »</TD></TR><TR><TD CLASS="quote"> Do you think that the TDC is not aligned right?</TD></TR></TABLE>probably not. Turn your crank pulley to tdc and check your cam gears and see if they line up also at tdc. Also check your dizzy to make sure it's properly installed.
ddn1313
08-04-2018 02:46 PM
I turned the crank to check if my timing belt was snapped. Do I have to return everything back to TD
jus2sho
15
10-09-2006 03:26 PM
specv5150
11
10-07-2004 02:39 PM
