can't adjust lights
Re: can't adjust lights (teckno_geek)
i have the same problem. take them out and there should be a 10mm screw that adjusts the lamp. but make sure its level. check the level by looking between the headlight there a balancer thing. (not sure what its called) thats how u adust them.
Re: can't adjust lights (HXvtec)
don't take it out. look in the manual and it explains how to insert a screw driver a certain way to adjust the headlights.
you insert the screw driver from the top, then turn the little gear thingie, you don't mess with the 10mm bolt.
Re: can't adjust lights (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip »</TD></TR><TR><TD CLASS="quote">don't take it out. look in the manual and it explains how to insert a screw driver a certain way to adjust the headlights.
you insert the screw driver from the top, then turn the little gear thingie, you don't mess with the 10mm bolt.</TD></TR></TABLE>
thats probably why my lights are screwed.
Re: (HXvtec)
I think the bolt/nut thing is connected to the gear. well, you insert the screwdriver from the top right above the gear thing. you have to insert at a diagnol, then the screwdriver fits into the gear, you turn the screwdriver, (turning the gear) and your lights are adjusted
Re: (pdiggitydogg)
oh yea, how do you lose an owner manual? i thought everyone just kept in the glove box...
edit: wasn't being rude, just wondering cuz i know others that have lost their manuals
Re: (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip »</TD></TR><TR><TD CLASS="quote">oh yea, how do you lose an owner manual? i thought everyone just kept in the glove box...
edit: wasn't being rude, just wondering cuz i know others that have lost their manuals</TD></TR></TABLE>
i lose everything
i lose everything
Re: (HXvtec)
its somewhere around here n e way my lights are screwed. i know what u guys are talking about. i kept turning the gear and nothing happened. i need to stop messin around with my car.
Re: (pdiggitydogg)
the one closest towards the side of the car adjusts up & down - the one towards the center (grill) adjusts horizontally I believe
search results
https://honda-tech.com/zerothread?id=597861
search results
Re: (HXvtec)
hey for reals i keep on turning that darn thingy magigy screwwy but still nothing happens. i don't know what the f@*k is going on with that head light. i turn that screw over and over in every direction but still the head light said, "not by the hair on my chinny chin chin." i'm about to junk the light if i can't fix it. it seems to be blinding everyone...
Re: (pdiggitydogg)
i'm turning the verticle one. to make it shine lower so it doesn't blind anyone. but nothing is happening. i can see the little teeth thingy truning but the light won't shine lower. this sucks.
mario_pic
12-18-2007 04:14 PM
. M i c h a e l
07-11-2006 05:08 PM
