head gasket problem
HELP - head gasket problem
Okay so Im in need of a new head gasket for my d16y7 and I am building it in the near future. Question - can I use a 75.5mm without boring/shaving my block?
Re: head gasket problem
Please read:
https://honda-tech.com/honda-civic-d...sting-3002401/
Then come back and edit your post to be compliant with all the basic rules for technical threads in this forum.
Failure to comply with the basic rules will result in a closed thread.
Thanks.
Thanks.
why would you use a 75.5mm without a bore?
that makes no sense, you cant re use it when you do a build if you plan on boring it then
get the factory piece, unless it was already bored to 75.5
