which has more potential... h22 or b18c on del sol?
im planning to do a swap on my del. the soch v-tech is okay for peel outs but i need something that'll pull me quick down the strip. so which is h22 turbo or gsr turbo. whats the ups and down... and please dont metion about the weight because it was a topic metioned earlier. i just want the one that'll get me the fastest slips.
Re: which has more potential... h22 or b18c on del sol? (Drift-King)
i would go with the h22 cause it's cheap and stronger than the b18 but save the turbo later cause with the h22 in ur del sol u'll do good on the track
Search owns all.
stock h22 turbo 262hp 215tq on 7lbs https://honda-tech.com/zerothread?id=930039
stock b18c1 219hp 168tq on 7lbs https://honda-tech.com/zerothread?id=658701
a few examples... but there are many variables that contribute to speed and hp
Modified by usdmike at 6:32 PM 8/12/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drift-King »</TD></TR><TR><TD CLASS="quote">my friend has a hb w/gsr turbo ran high 13's. can a h22 turbo do better?</TD></TR></TABLE>
your friend with the hb cant drive for **** then. ive seen h22 del sols break axles alot
Re: which has more potential... h22 or b18c on del sol? (AzntaggeR)
go wit the GSR turbo it will be a lot better in the long run. plus its not gonna give you axle/traction like the h22 will
Re: which has more potential... h22 or b18c on del sol? (jdm98hb)
gsr, more aftermarket support and has similar power potential without the headaches of broken axles.
Disgustipated
34
01-21-2011 02:23 PM
wesleyinsanho
02-09-2004 03:10 PM
