h22a miss-fire help
h22a miss-fire help
recently had a h22a swaped in my 92 cx hatch back.
The motor has been miss firing in Cyl. 1. cyl. 4.
yes, i drive on two cylinders daily. for a two months.
the injectors are injecting on the exhaust stroke, i am running on pure fumes.
i have a p28 chipped with a proven h22a stock basemap.
the p28 nor p13 are going into diagnostic mode to check my C.E.L. that i have.
- Checked the dizzy, its fine.
- Checked timing, its fine.
- Checked compression. seemed fine 270 across. but will repeat a compression test
-Checking the wirring harness.
-Checking the sub-harness going to ecu.
harness thats currently in there is a 92 stock harness with vtec seperate wires and pin out.
i do have a h23 obd1 harness, might throw obd2 injectors in to run with out resistor box.
Also, taking a look at the sub harness, its pretty f**d, am going to go threw all the pin outs in all the ports.
Would love some help if you guys have any idea what it COULD be.
