h22 into 92HB Q's how to need help!!??
i need help with this swap. i have a few questions. i know i need a mount kit but do i need to buy new axles? or can i use the stock ones? and about the wiring i have a 92 si HB so can i just just re pin the h22 harness or what mods need to be done to it? also how hard is it to put the cable shifter in and what do you have to do? thanks. any recomedations to make it easier are very appreciated!
Re: h22 into 92HB Q's how to need help!!?? (92spoonHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92spoonHB »</TD></TR><TR><TD CLASS="quote">any recomedations to make it easier are very appreciated!
I recommend you search
This topic has been covered extensively.
there is stuff on it but only about what mount kit i should buy. i was wonderin if i needed to buy axles or not and how hard it would be to put the cable shifter in?
what do you do about wiring in the h22? what wire harness do you use? or do you just pin the h22 harness into the eg wiring?
https://honda-tech.com/zerothread?id=362984
took me 2 seconds to find
have fun it is a 7 page thread
