h22
h22
i have a delsol im going to buy do a h22a1 swap in it...
i found a fully built motor but it just has a intake and throttle
body on it.. i was wondering if anyone can help me out with my
swap im needing axles,header,ecu,harness,a radiator that will
work in a delsol. this motor is built for boost so if you have a
turbo header let me know also ... im new to the import world
i was mainly in to mini trucks but i want a import now.. also i need
the accsories like altornator and all that stuff i dont need power sterring
or curis contorl... let me know asap cause if i cant get all the parts i will have to
pass on the motor and that will suck caue it runs 7.5 in the 1/8 12.1 in the 1/4
any parts that will help thanks josh you can email me at sick_kustoms@msn.com also ...
YOU CAN.... USE THE F22 SHIFT LINKAGE, NEED UPGRADED RADIATOR, YOU CAN USE THE PRELUDE HARNESS (P13) OR YOU CAN USE THE EX/SI CIVIC HARNESS (P28) ENGINE LIGHT WILL COME ON... AXLES ONE FROM AN EF AND ANOTHER FROM AN ACCORD... (TRUST ME THATS HOW I HAVE MY SWAP) YOU MIGHT NEED TO CUT THE TRANNY MOUNT THAT IS ON YOUR PASSENGER SIDE (CUT AND WELD!) ABOUT THE AXLES, YOU CAN BUY THEM LIKE SPECIALLY MADE FOR A DEL SOL WITH AN H SERIES SWAP...WHICH EVER IS GOOD.
