GSR swapped 99 civic Start up problem!!!
Old 06-20-2010, 05:42 PM
gsrekcoupe12's Avatar
Default GSR swapped 99 civic Start up problem!!!
Ok so Im new to the posting scene. So bear with me. About a month ago I dropped a cylinder in my civic. Ive got a 96 model gsr swapped into it. When i pulled the head, we noticed a chunk out of the piston. well we ended up replacing the pistons, rods, and all the bearings and heard from the machine shop that the head (a p72-2) was cracked in several places. SO i bought a p72-1 head and installed it, got everything together and torqued down, went to start it, and it wouldnt start. after manipulating a few things, it will run on cylinders 1 2 and 3. but with a spark plug and wire in cyl 4 it wont start. period. but when removed, runs on 3 cylinders and has quite a bit of compression coming out of num 4 hole. help. Ive been scratching my head for 2 weeks trying to get this thing running again.
Austin
Old 06-20-2010, 07:11 PM
LuczOr's Avatar
Default Re: GSR swapped 99 civic Start up problem!!!
do you have spark at cylinder 4?
Old 06-20-2010, 09:42 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Maybe the timing is off?
Old 06-20-2010, 10:51 PM
92bseries's Avatar
r the wires connected right on ur dizzy, maybe its misfiring cuz u have a wire crossed from the dizzy to spark plugs
Old 06-20-2010, 11:03 PM
jspecb18vtec's Avatar
it could be your harness bad injector dizzy could be ready to take a dump on you. just go through the list. good luck!
Old 06-21-2010, 05:23 AM
its getting spark and fuel. but if the num 4 hole gets plugged in any way (spark plug or wire) it will niot start. but without the plug and wire, it runs on 3 cylinders. timing is right. its been timed 65 million times on 2 dif dizzy's
actek988
01-14-2011 05:49 PM
guido45
02-01-2008 06:47 PM
prelude1897
03-27-2006 01:38 PM
hybridej7
09-10-2005 05:02 AM
AIWFCIATR
07-23-2004 11:54 PM
Quick Reply: GSR swapped 99 civic Start up problem!!!
